Running board support
sparklymarkly
Can someone answer a quick question please?
I've just finished stripping my frame ready for painting and am slightly confused about the rear footboard supports.
The RH one unbolted but the LH one appears to be welded on - is that correct or am I missing something obvious?
No that's right enough, the Kickstart side comes off so you can get better access to the engine.
sparklymarkly
Thanks for that.
I thought it must be fixed but just needed to be sure.
It's the first techie question I've had to ask & I haven't stripped a Lammy down for nearly 30 years so I'm
quite pleased with myself!
Expect lots more once I start putting it back together though!!
