Excessive white smoke
Andy17764
Main scooter: Lambretta li 186 imola
Please can any body help . After a t5 engine re build exhust blows excessive white smoke . What. Could be the reason ?
goldeneye
drive side oil seal failure. probably has a nick in it, not seated properly, or the spring came off it when building the motor, thatd be first port of call. too much 2 stroke could have the same symptoms, but after a re-build, my moneys on the oil seal. time to get the spanners out i"m afraid. :cry:
hungdog
Are you the new pope ? :baddevil:
molibdimum
Make sure you haven't filled up with diesel.
Now who would do such a stupid thing :oops:
Andy17764
goldeneye wrote:drive side oil seal failure. probably has a nick in it, not seated properly, or the spring came off it when building the motor, thatd be first port of call. too much 2 stroke could have the same symptoms, but after a re-build, my moneys on the oil seal. time to get the spanners out i"m afraid. :cry:
You were right oil seal had a small nick in it . Thanks alot all changed and running fine . Thanks again !
