Bitubo front shocks
Posted: Sun Mar 25, 2012 1:40 pm
by grimspeed
Whats the difference bitween disc and drum bitubos ? Anyone ?
I have a drum set up at the moment and i am going to change to a floating disc !
So the real question is do i need a new front shock or can i still use my old one ?
Re: Bitubo front shocks
Posted: Mon Mar 26, 2012 12:09 pm
by gaz_powell
I had a drum type bitubo and changed to a old type grimeca set up (criss cross front hub)- onlt thing i had to do was to machine down the head of the two M8 bolts that hold the caliper to the back plate - later changed to a standard vespa disc set with star shaped hub and no additional problems at all
my shock is the one with the remote reservoir
hope this helps
gary
Posted: Mon Mar 26, 2012 8:24 pm
by grimspeed
Thanks for that ! Most helpfull !
Posted: Tue Mar 27, 2012 11:33 am
by Fruitjuice
gaz_powell wrote:I had a drum type bitubo and changed to a old type grimeca set up (criss cross front hub)- onlt thing i had to do was to machine down the head of the two M8 bolts that hold the caliper to the back plate - later changed to a standard vespa disc set with star shaped hub and no additional problems at all
hope this helps
gary
Instead of machining down the bolts, I prefer to chamfer the holes in the caliper holder and fit chamfered flush fitting bolts...
