new engine options?
muffster
Xbox live gamer tag: muffinator233
Main scooter: LI 125 S3
Hi folks.
I'm just about to slowly start the resto of a 150 SX Special. It didn't come with an engine so i'm wondering what the best thing is to do. I haven't yet got a budget or timescale.
I want to run a decent motor but i don't know enough yet about RB or muggy kits. obviously these are expensive, so should i buy an engine casing and do it myself, that way i can do it slow time and not have the initial outlay of a full engine.
But is there a limit to what i can do with an Sx engine casing with regards to heads, exhausts etc.
It's a bit of an ambiguous question but your opinions please on one versus the other.
Ta very much.
muffster
Anyone, advise please? :bigsm:
Ta.
Any small block kit will fit a small block As standard or if you have the block converted to 200 stud spacing any large block kit will fit
bristolmod
personally I'd try to get hold of an SX150 casing- that way the complete bike retains more of its original "pedigree" (also they are a lot less expensive than 200 casings).
You can then build up the engine to your spec. There's many "small bore" kits available that will walk all over a standard 200 engine- also you can put in your choice of gearbox.
It all depends what you want the engine to do for you
Chris
Scootering since 1968.
muffster
Hi mate,
Thanks for that. I will try and get hold of an engine casing. i just missed out on one on ebay last week!!
I think i will go down the route of building my own and getting the bits gradually.
Can you recommend a particualr type of smallbore kit? And what determins the choice of gearbox?
Many thanks.
DaveTomo
Main scooter: SX 200
Italian LI 150 gearbox good all rounder
lammydave
you will get different opinions on kits
but for my money, a mugello 186 kit is the way to go...
have fitted three of these to different scooters, and the performance is great... and can be used straight out of the box....
Stevo
How is he Mugello in comparison to the Casa kit guys? I plan to run a clubman and 22mm through the airbox. I like the look of the RT195 too but not the price!
muffster
Lammydave. What sort of carb and exhaust are suitable for a muggy. Kit.
And are they suitable for a small bore engine casing?
Thanks.
muffster wrote:Lammydave. What sort of carb and exhaust are suitable for a muggy. Kit.
Thanks.
I think he uses 28mm Dellortos and Ancillotti clubmans.
Mugello normally available in 186 for small block casings and 200 & 225 for large block casings.
