jimmers, LTH, MB manifold
sydduckett
I need more clearance between my vhsh carb and the panel to get a marchold filter on (the smallest i can find) Its an rb20 with the standard AF manifold the kit came with. Im already running offset cones and need at least 10 more mm. This could be a combination of the angle of the Carb and it sitting further back.
Does anyone know which of the 3 i have mentioned sits the farthest back? Im also hoping to get some more clearance by using a shorter mount, currently have the Andy francis one with 2 jubilee clips.
Ta
Sef
Ian Hepworth
sydduckett wrote:I need more clearance between my vhsh carb and the panel to get a marchold filter on (the smallest i can find) Its an rb20 with the standard AF manifold the kit came with. Im already running offset cones and need at least 10 more mm. This could be a combination of the angle of the Carb and it sitting further back.
Ta
Sef
Unless Mark has been keeping it quiet MB don't make a manifold for the RB kit.
sydduckett
Ta
Sef
ill cross tat one off the list then.... :D
speak to jimmers on here
sydduckett
Cheers mark, ill pm him
