disc brake
Posted: Sun Mar 04, 2012 4:55 pm
by yarblockios
I've got an internal brake that someone converted to hydraulic can it be changed back to normal by using a new actuator.
Many thanks
Re: disc brake
Posted: Sun Mar 04, 2012 5:35 pm
by RICSPEED
quick answer not worth the bother .. unless the cylinder is held with a clip as per standard
Re: disc brake
Posted: Sun Mar 04, 2012 8:44 pm
by yarblockios
Thanks for that mate quick straight to point answer & no unfortunately its not got the clip holding it in am I gonna have trouble if I wanna change the disc or pads.
Re: disc brake
Posted: Sun Mar 04, 2012 10:52 pm
by RICSPEED
it would be far better to trade /swap for a standard one as cost to re machine yours would be beyond what a back plate would cost you ..the scootrs ones fit original hubs
Re: disc brake
Posted: Sun Mar 04, 2012 11:57 pm
by corrado
yarblockios wrote:......... am I gonna have trouble if I wanna change the disc or pads.
No, changing the disc or pads would be the same as on a none hydraulic brake.
