disc brake
yarblockios
Main scooter: Gp200
I've got an internal brake that someone converted to hydraulic can it be changed back to normal by using a new actuator.
Many thanks
quick answer not worth the bother .. unless the cylinder is held with a clip as per standard
yarblockios
Main scooter: Gp200
Thanks for that mate quick straight to point answer & no unfortunately its not got the clip holding it in am I gonna have trouble if I wanna change the disc or pads.
it would be far better to trade /swap for a standard one as cost to re machine yours would be beyond what a back plate would cost you ..the scootrs ones fit original hubs
yarblockios wrote:......... am I gonna have trouble if I wanna change the disc or pads.
No, changing the disc or pads would be the same as on a none hydraulic brake.
