Page 1 of 2
KICKSTART CLICKING/ENGAGING
Posted: Thu Mar 01, 2012 8:28 pm
by 20QL
After my engine rebuild, my kickstart is clicking as I push it forward and also mechanically locks up when I try to wheel it backwards when in gear, but is fine in neutral?
Its a GP 200 and when I have moved the kickstart around on the splines it doesnt sit right?
Any solutions to this problem please?
Re: KICKSTART CLICKING/ENGAGING
Posted: Thu Mar 01, 2012 8:49 pm
by WINTERMODEL150
Hi,what have you changed to create such a problem?
Dean
Posted: Thu Mar 01, 2012 8:54 pm
by 20QL
a new clutch bell was fitted but I did grind the kickstart shaft to stop it catching the top clutch plate.
Posted: Thu Mar 01, 2012 8:56 pm
by 20QL
A new crownwheel was alsao fitted
Posted: Fri Mar 02, 2012 10:37 pm
by wack 63
The crownwheel could be too near the endplate or studs causing the chain rivets to catch?
Posted: Fri Mar 02, 2012 11:03 pm
by 20QL
Cheers Will check that tomoro! A mate reckons the kickstart has not been turned/tensioned enough or kickstart shaft piston stud is fouling as not in the correct position.
Thanx again.
Posted: Sun Mar 04, 2012 12:11 am
by 20QL
Think ive sussed it? Kickstart ramp on GP End plate is worn so allowing the kickstart piston to insert further than usual. Didnt look too worn on first inspection but on further inspection was about 1mm deeper than should be. I Will buy one at wicksteed tomorrow if it does the same the strip will commence! Cheers
Posted: Sun Mar 04, 2012 1:18 am
by DaveTomo
you could cut the ramp off the GP end plate so that its the same as an LI/SX,then buy a ramp for your sidecasing .That way you keep the (I presume) matched endplate to the casing,saves titting about having to re-shim it etc and you've got a adjustable kickstart
have a look at this
http://scooterotica.org/forum/viewtopic.php?f=7&t=14694
Posted: Tue Mar 06, 2012 12:20 am
by 20QL
On further inspection it looks like the end plate ramp is worn(indian). Bought a new italian endplate at wicksteed the weekend so will fit that when time allows, but cheers for assistance!
Posted: Sat Mar 10, 2012 10:47 pm
by 20QL
Sorted it! Fitted a New Italian endplate. Cheers
