KICKSTART CLICKING/ENGAGING
20QL
Main scooter: GP 225 TS1
After my engine rebuild, my kickstart is clicking as I push it forward and also mechanically locks up when I try to wheel it backwards when in gear, but is fine in neutral?
Its a GP 200 and when I have moved the kickstart around on the splines it doesnt sit right?
Any solutions to this problem please?
WINTERMODEL150
Hi,what have you changed to create such a problem?
Dean
20QL
a new clutch bell was fitted but I did grind the kickstart shaft to stop it catching the top clutch plate.
20QL
A new crownwheel was alsao fitted
wack 63
Main scooter: '71 GP TS1
The crownwheel could be too near the endplate or studs causing the chain rivets to catch?
20QL
Cheers Will check that tomoro! A mate reckons the kickstart has not been turned/tensioned enough or kickstart shaft piston stud is fouling as not in the correct position.
Thanx again.
20QL
Think ive sussed it? Kickstart ramp on GP End plate is worn so allowing the kickstart piston to insert further than usual. Didnt look too worn on first inspection but on further inspection was about 1mm deeper than should be. I Will buy one at wicksteed tomorrow if it does the same the strip will commence! Cheers
DaveTomo
Main scooter: SX 200
you could cut the ramp off the GP end plate so that its the same as an LI/SX,then buy a ramp for your sidecasing .That way you keep the (I presume) matched endplate to the casing,saves titting about having to re-shim it etc and you've got a adjustable kickstart :D have a look at this http://scooterotica.org/forum/viewtopic.php?f=7&t=14694
20QL
On further inspection it looks like the end plate ramp is worn(indian). Bought a new italian endplate at wicksteed the weekend so will fit that when time allows, but cheers for assistance!
20QL
Sorted it! Fitted a New Italian endplate. Cheers
    Users browsing this forum: Semrush [Bot] and 17 guests
