Crank swap.
Posted: Thu Apr 02, 2009 11:42 pm
by lammy mark
I have a series 3 LI engine. I have just discovered that the crank is wrecked. A good mate has donated a GP 200 crank, mag bearing & a flywheel. What else will I need to upgrade / replace in terms of seals & bearings ?
Any help or suggestions would be appreciated
Cheers,
Mark
Re: Crank swap.
Posted: Fri Apr 03, 2009 12:08 am
by J1MS
If its an early Six pole, points LI stator, you will need a later type stator to go with the flywheel ( unless thats already with the GP flywheel) because the internal diameter of the stator is smaller on a points LI than on a GP, (because of the GP boss diameter) and that can cause problems....
Re: Crank swap.
Posted: Fri Apr 03, 2009 8:39 am
by eibargum
If its an Indian crank it would be wise to have the bigend bearing changed, better safe than sorry.
Re: Crank swap.
Posted: Fri Apr 03, 2009 8:44 am
by lammy mark
J1MS wrote:If its an early Six pole, points LI stator, you will need a later type stator to go with the flywheel ( unless thats already with the GP flywheel) because the internal diameter of the stator is smaller on a points LI than on a GP, (because of the GP boss diameter) and that can cause problems....
Sorry.. I should have mentioned that I have a new 12 Volt S.I.L. stator to go in... the old one had been partially sheared.
Re: Crank swap.
Posted: Fri Apr 03, 2009 1:04 pm
by andylaw7
sounds good enough to go just bear in mind that the crank your mate has supplied has got the bearing race on it . and the mag flange has gp bearing to suit said race track .
Re: Crank swap.
Posted: Fri Apr 03, 2009 9:29 pm
by lammy mark
Thanks for the advice.
