bearing drifts?
servetakid
Hi,
Can anyone recomend a set of drifts for doing a lambretta engine?
Or would something like this be any good?
http://www.powertoolworld.co.uk/draper- ... 09540.html
Looks like it would be if any of the drifts matched any of the bearings, I don't have any to hand to check
I think from memory the magneto seals are 46 and 52 mm, so I think the bearing will be 52mm OD
The drive side seal is 50mm OD and the bearing is 62mm.
I think there isn't one small enough there for front wheel or cluster bearing either.
Probably better off looking for a specific lambretta set Madspeed do them on ebay from time to time.
Personally I use an appropriate sized socket and never had much trouble doing so.
alcoholic maniacs sc
servetakid wrote:Hi,
get a plumbing torch on any baring and it will push out once the alloy has expanded around it. you shouldnt have to drift any baring out, certainly you should never drift a baring in. always building engines and never force anything,theres a reason if it doesnt fit. :geek:
col@garageartwerks
get in touch with madspeed on here he does a set
I use this tool myself, it can be used for most bearings on a Lambretta casing.
http://www.richpresley.co.uk/lambretta- ... l-42-p.asp
Used in conjunction with a bit of heat and various sized washers and / or old bearings it's mastered every job I've tried so far.
It's not cheap but it's cheaper than one visit to a "professional" to fit or remove a bearing and it'll last you a lifetime. Along with a £4 spring puller it's about the best tool I've ever bought. Personally I'd never use a drift to fit or remove bearings, I'm too unlucky not to have a major mishap using one.
MADSPEEDRB260
Main scooter: lambretta gp200
Nice one guy's yes if you need a set just give us a bell mate 07884075408
Having said use a socket I did my mag bearing yesterday, put the bearing on the top of the hole and heated the outside with a blow torch. After about a minute heating it round evenly the bearing just dropped right in!
On using pullers, isn't there more of a risk of pulling it right thru? Tapping it in gently at least you can hear when the sound changes that it's home.
