Page 1 of 2
Settings Jetex 22mm+Stage4+Sterling exhaust
Posted: Sun Feb 26, 2012 10:06 pm
by KOREBCN
Hi!
I want to know the optimal main jet for a Jetex 22mm.
SIL STAGE 4, Sterling Exhaust, Air Filter Type Tino Sacchi, Gear Box SX200.
Thanks!
Re: Settings Jetex 22mm+Stage4+Sterling exhaust
Posted: Sun Feb 26, 2012 11:14 pm
by WINTERMODEL150
KOREBCN wrote:Hi!
Thanks!
Hi,I would start off with a 130 then work backwards until it runs clean without spluttering.
You may end up around a 123 / 125
Dean
Posted: Mon Feb 27, 2012 12:53 pm
by KOREBCN
hello,
The 123 is short.
The 130 does not let up revolutions the engine.
Right now I have a 125 with a return air screw, not up revolutions the engine.
A question, you have to adjust the air screw?
thanks
Posted: Mon Feb 27, 2012 7:43 pm
by WINTERMODEL150
KOREBCN wrote:hello,
The 123 is short.
thanks
Main jet has nothing to do with the air screw adjustment ,can you be a little more specific with what info you require?
Dean
Posted: Mon Feb 27, 2012 9:18 pm
by KOREBCN
my engine does not work well 123, 125 and 130.
They say a 123/125 is optimal for my engine, but I do not work. The engine not up revolutions
It may be by adjusting the air screw?
possible solution?
Posted: Mon Feb 27, 2012 10:54 pm
by WINTERMODEL150
Hi,I take it you have a 200 jetex carb and not a 150 as the slides are different,you should be running a 48 pilot jet if not change it.
The engine not up revolutions :wtf: will it tick over smoothly?sounds like you my have others issues.
Posted: Tue Feb 28, 2012 8:22 am
by KOREBCN
My engine is a 200 with Jetex 22
It used to take a 118 main jet with standard filter and the engine revolutions is good.
Tino Sacchi Filter and 118 ill.
I tried 123, ill.
I tried 130, ill.
I tried 125, ill.
Posted: Tue Feb 28, 2012 7:35 pm
by gerryjunior
WINTERMODEL150 wrote:Hi,I take it you have a 200 jetex carb and not a 150 as the slides are different,you should be running a 48 pilot jet if not change it.
How do you tell the difference between a 200 and a 150 jetex.. i know the dellorto had different slide no's but i dont remember seeing no's on a jetex?
Posted: Tue Feb 28, 2012 9:47 pm
by KOREBCN
hi
idle jet 45
pilot jet 50
Posted: Tue Feb 28, 2012 10:19 pm
by WINTERMODEL150
gerryjunior wrote:WINTERMODEL150 wrote:Hi,I take it you have a 200 jetex carb and not a 150 as the slides are different,you should be running a 48 pilot jet if not change it.
The 150 slide on a jetex has a cut out in one side of the slide the 200 doesn't simple
Dean
