Settings Jetex 22mm+Stage4+Sterling exhaust
KOREBCN
Hi!
I want to know the optimal main jet for a Jetex 22mm.
SIL STAGE 4, Sterling Exhaust, Air Filter Type Tino Sacchi, Gear Box SX200.
Thanks!
WINTERMODEL150
KOREBCN wrote:Hi!
Thanks!
Hi,I would start off with a 130 then work backwards until it runs clean without spluttering.
You may end up around a 123 / 125
Dean
KOREBCN
hello,
The 123 is short.
The 130 does not let up revolutions the engine.
Right now I have a 125 with a return air screw, not up revolutions the engine.
A question, you have to adjust the air screw?
thanks
WINTERMODEL150
KOREBCN wrote:hello,
The 123 is short.
thanks
Main jet has nothing to do with the air screw adjustment ,can you be a little more specific with what info you require?
Dean
KOREBCN
my engine does not work well 123, 125 and 130.
They say a 123/125 is optimal for my engine, but I do not work. The engine not up revolutions
It may be by adjusting the air screw?
possible solution?
WINTERMODEL150
Hi,I take it you have a 200 jetex carb and not a 150 as the slides are different,you should be running a 48 pilot jet if not change it.
The engine not up revolutions :wtf: will it tick over smoothly?sounds like you my have others issues.
KOREBCN
My engine is a 200 with Jetex 22
It used to take a 118 main jet with standard filter and the engine revolutions is good.
Tino Sacchi Filter and 118 ill.
I tried 123, ill.
I tried 130, ill.
I tried 125, ill.
gerryjunior
Xbox live gamer tag: no
Playstation gamer tag: no
Main scooter: lambretta li 2
WINTERMODEL150 wrote:Hi,I take it you have a 200 jetex carb and not a 150 as the slides are different,you should be running a 48 pilot jet if not change it.
How do you tell the difference between a 200 and a 150 jetex.. i know the dellorto had different slide no's but i dont remember seeing no's on a jetex?
KOREBCN
hi
idle jet 45
pilot jet 50
WINTERMODEL150
The 150 slide on a jetex has a cut out in one side of the slide the 200 doesn't simple :D
Dean
    Users browsing this forum: No registered users and 24 guests
