Lth viton sealed exhaust flange.
Posted: Thu Feb 23, 2012 9:53 pm
by Ihateyoubutler
Two questions really. Anyone know if an mb devtour u bend and a jl one are the same? Reason I'm asking is that there's some jl compatable exhaust flanges on ebay with viton seals. I'm sure they are pretty close.
Second question is has anyone used one, are they any good? My devtour always seems to leak however much goo I try to seal it with.
Thanks.
Re: Lth viton sealed exhaust flange.
Posted: Thu Feb 23, 2012 10:05 pm
by soulsurfer
I had this problem with my Dev-Tour, mine was worn round the stub. I haven't tried it on a Franspeed stub, but now you mention it, I'll give it a try and let you know
Posted: Fri Feb 24, 2012 3:10 pm
by soulsurfer
The Dev-Tour stub manifold measures a tad over 42mm so this could possibly do the trick.
http://www.lambretta-teile.de/Exhaust-f ... a-Imola-RB
Posted: Fri Feb 24, 2012 4:05 pm
by Fruitjuice
Bought one of tehse Viton seal exhaust stubs from LTH two years ago, and the Viton seals snapped twice in short period and when reporting back to LTH they found the grooves were not deep enough in the stub and in many cases sheared the seals when mounting.
they were working on a revised thicker walled version with deeper groove, but didn't look into it anymore since.
Might be worth asking Marcus if they got around solving that?
Posted: Fri Feb 24, 2012 9:20 pm
by Ihateyoubutler
Thanks all (as always) for the replies. Lambretta and ''problem solved'' never seem to come easy :biggrin:
Thanks again.
