GT silent block's
Posted: Sun Feb 19, 2012 8:58 pm
by grimspeed
Any of you having problems removing GT silent blocks ?
Can you get a puller to do the job ?
Re: GT silent block's
Posted: Fri Feb 24, 2012 6:06 pm
by grimspeed
I found that when i went for my MOT that bearings in the swing arm needed replacing.
When i came to remove the swing arm that due to lack of grease that everything had seized solid !
And the bar going through the silent block's on the casing had also seized solid in the silent blocks.
Out came the angle grinder . then the drill but now i have a damaged silent block and i need to get it out !
Any ideas ?
Posted: Sat Mar 03, 2012 11:02 pm
by e type
Do you mean engine mounts Or swing arm bushes
Posted: Fri Mar 09, 2012 5:33 pm
by grimspeed
Rubber engine mounts !
Posted: Fri Mar 09, 2012 7:04 pm
by shocky
grimspeed wrote:Rubber engine mounts !
http://www.vespaspares.co.uk/spares/par ... %3D6&uid=0
this bit i removed the one from my dragster with a socket and threaded bar and a tube on the outside ive never seen a tool to do it maybe contact cheeky thomas on the GTS forum
i uprated my dragster ones with a SOLID kit from pm tuning
Posted: Sat Mar 10, 2012 7:08 pm
by e type
As shocky said threaded bar an socket way
Posted: Sat Mar 17, 2012 10:42 am
by grimspeed
All sorted now . I made a tool specificly for the job and it works a treat !
