Any of you having problems removing GT silent blocks ?
Can you get a puller to do the job ?
GT silent block's
grimspeed
- registered user
- Main scooter: gp 283 kx
- Contact:
I found that when i went for my MOT that bearings in the swing arm needed replacing.
When i came to remove the swing arm that due to lack of grease that everything had seized solid !
And the bar going through the silent block's on the casing had also seized solid in the silent blocks.
Out came the angle grinder . then the drill but now i have a damaged silent block and i need to get it out !
Any ideas ?
Any ideas ?
Do you mean engine mounts Or swing arm bushes
http://www.vespaspares.co.uk/spares/par ... %3D6&uid=0grimspeed wrote:Rubber engine mounts !
this bit i removed the one from my dragster with a socket and threaded bar and a tube on the outside ive never seen a tool to do it maybe contact cheeky thomas on the GTS forum
i uprated my dragster ones with a SOLID kit from pm tuning
As shocky said threaded bar an socket way
