reverse pull drum brake : good or not ?
Posted: Wed Apr 01, 2009 11:01 pm
by Soulpunk
hows a reverse pull drum brake ?
any better ?
risk in locking / rubbing ?
Re: reverse pull drum brake : good or not ?
Posted: Wed Apr 01, 2009 11:28 pm
by J1MS
Have done a few reverse pulls on drum brakes.....they work but can be a little sharp......If you decide to do a reverse pull, its best to make sure there is a good chamfer on the brake shoe leading edges as this can reduce the tendancy for the brake to snatch on....
Posted: Thu Apr 02, 2009 10:36 am
by Ricko
Not recomended! Unless you want to lock up the front end flip over the top and suffer serious damage to yourself and scoot! :o
Knowledge!!!!!!!!!!!!!
Rick. :shock:
Posted: Thu Apr 02, 2009 2:46 pm
by eibargum
Ive just done one and to be honest its not that much better, shorter cable though so maybe less stretch, not rearly worth the effort IMO.
Posted: Thu Apr 02, 2009 6:56 pm
by jonny snatchsniffer
if you have a spare clutch arm it can be straightened somewhat and used as a front brake arm, it just gives you more leverage, no doubt alot on here wont like the idea just as the reverse pull is dodgy
