GP chain case
Are there GP side cases out there with the ramp holes bored and tapped?
I'd like to use the GP style clutch but replace the end plate with the li style ramp
DaveTomo
Main scooter: SX 200
I just drilled and tapped mine,you can see on the sidecasing where the holes are supposed to be,what I mean is the casing isn't blank there are circular marks where originally the holes would have been.Here's one I made earlier :D
rosscla wrote:Are there GP side cases out there with the ramp holes bored and tapped?
some earlier ones are yes ..but as said easy enough to drill out and tap them
