Stupid Agusto 6000 Timing Question
ArmandTanzarian
hello all,
stupid question I know but....
It's been so long since I set up my Agusto 6000 I've forgotten what the start and end points should be.
What should the timing start off at and what should it retard to at high revs? The engine is a 240 mugello with an LTH reed.
fred
I suppose it's personal preferance, mines 21 deg at tickover 15 at around 6k.
mine may be a 7000 tho.
fred
phil23fair
ArmandTanzarian
All a bit academic for the moment. The Agusto has gone wrong. It's causing a serious misfire.
I like the idea of the variable ignition though. Are Agusto's still the one to go for or are there better thing available now.
ducksta
chislespeed makes his own give martin a ring
ArmandTanzarian
ducksta wrote:chislespeed makes his own give martin a ring
To me, the Chiselspeed box sounds a bit too clever for its own good. 16 different settings! How do you set up something with that much scope for adjustment.
ducksta
ask martin when you buy one he will help you out with the settings
ArmandTanzarian wrote:are there better thing available now.
Richard Taylor's ignition kit.
ArmandTanzarian
http://www.granturismo.pwp.blueyonder.c ... nition.htm
That looks like it might cost a tiny bit more than an Agusto or a Chiselspeed box
ArmandTanzarian wrote: That looks like it might cost a tiny bit more than an Agusto or a Chiselspeed box
Only in the short term. If your Agusto box goes pop, causing your engine to go pop, 300 miles from home.. Richard's kit is cheaper :)
It also looks awesome. Which is worth the asking price alone.
    Users browsing this forum: Semrush [Bot] and 8 guests
