trail tech vapor tacho problem
ssteam177
Main scooter: vba malossi 221, api series2
ive set up the speedo,back light and cht no problems but i cant seem to get a pluse off the plug lead no matter how many times i wind the pick up wire around the ht lead. where is the best place to get the pluse from????
ps engine is sil 200 with sil stator and lightened flywheel with agusto 600 with bgm regulator
thanks in advance for any advice given
IT'S NOT WHAT YOU BUY
IT'S WHAT YOU BUILD!!!!
gavi4t
Main scooter: lambretta gp450
try one of the terminals on your coil i think ive got mine wired off the red wire thats on my 450 motor mind and works fine if you read the pamphlet that comes with the vapour it gives you diagrams to wire it up this way hope this helps regards gavi 8-)
ssteam177
cheers ill give that a go in the morning
ssteam177
i tried that this morning still no joy, i have it set on program 1 as pamphlet says for 2t any other ideas people ?????
ssteam177
i think the ht lead maybe too insulated, and i cant get it to read off the cdi, someone must be on here that has set one up on a lammie ????? or that ive run the sensor wire for the rev counter in with loom
jonashford
Sounds strange, I got mine working easily, U sure u havent mixed up the plug in sockets??? I know 2 are the same cant remember which ones they are tho. I wrapped mine round the ht lead near the coil about 5 or six times worked first time.
I did get a problem with the display staying on tho it shud go off after 5 minutes if it doesnt sense the front wheel moving, after a bit of investigation I discovered that if u park the scoot up and the magnet and sensor are in line it doesnt switch off the display, something to check then when parking up.
rbgaz
never had a prob with rev counter myself just wraped it rd the ht lead , good bit kit very acurate sp eedo an rev count only fault ive found is when riding in heavy rain the speedo stops
