rapido 225 with 30mm dell phbh
king of the hill
any ideas on carbset up for this ?
rapido 225 race with modified scootrs exhaust and 30mm phbh
greetz
tim
J1MS
128 or 130 main, 55 pilot and an x7 needle on the second clip is usually close.....But this is only a suggestion for a starting point...... dont go fitting it and think that it will be ok...do a couple of plug checks to see if its running right and if not ... if your close to a dyno center get it dynoed...All the best 8-) 8-)
ferritt
I RAN MINE IN ON THE ABOVE JETTING, NOW RUNNING A 122 MAIN.
J1MS
ferritt wrote:I RAN MINE IN ON THE ABOVE JETTING, NOW RUNNING A 122 MAIN.
This is the jetting I put in these as a starting point.... usually having to jet down to 122-125 :!:
ferritt
NOT TRYING TO CONTRADICT YOU, JUST THOUGHT I COULD HELP OUT WITH FINAL JETTING ONCE RUN IN MATE.
king of the hill
thanks for all replys !!
got about the same ideas as you lot and it turned out ok for running in .
greetz
tim
    Users browsing this forum: Google [Bot] and 11 guests
