any ideas on carbset up for this ?
rapido 225 race with modified scootrs exhaust and 30mm phbh
greetz
tim
rapido 225 with 30mm dell phbh
king of the hill
- registered user
- Contact:
128 or 130 main, 55 pilot and an x7 needle on the second clip is usually close.....But this is only a suggestion for a starting point...... dont go fitting it and think that it will be ok...do a couple of plug checks to see if its running right and if not ... if your close to a dyno center get it dynoed...All the best
I RAN MINE IN ON THE ABOVE JETTING, NOW RUNNING A 122 MAIN.
This is the jetting I put in these as a starting point.... usually having to jet down to 122-125ferritt wrote:I RAN MINE IN ON THE ABOVE JETTING, NOW RUNNING A 122 MAIN.
NOT TRYING TO CONTRADICT YOU, JUST THOUGHT I COULD HELP OUT WITH FINAL JETTING ONCE RUN IN MATE.
king of the hill
- registered user
- Contact:
thanks for all replys !!
got about the same ideas as you lot and it turned out ok for running in .
greetz
tim
greetz
tim
