Cylinder temperature
Posted: Fri Jan 20, 2012 9:14 pm
by diesel
Can anyone tell me what temperature the exterior of a lambretta alloy cylinder can reach? Im thinking particularly of the body of the cylinder not so much the fins.
Steve
Re: Cylinder temperature
Posted: Fri Jan 20, 2012 9:37 pm
by coaster
I don't know the answer but I dfo know that the temp will vary depending where you measure it. It will obviously be hotter around the exhaust and at the top of the cylinder.
Posted: Fri Jan 20, 2012 10:04 pm
by WINTERMODEL150
Hi,anywhere from 180-230 degrees c at the spark plug at constant speeds depending on engine set up, a piston will seize at anything over 250 degrees c ,hope this helps.
Dean
Posted: Fri Jan 20, 2012 10:27 pm
by diesel
Thats great ,thanks
