Cylinder temperature
diesel
Can anyone tell me what temperature the exterior of a lambretta alloy cylinder can reach? Im thinking particularly of the body of the cylinder not so much the fins.
Steve
I don't know the answer but I dfo know that the temp will vary depending where you measure it. It will obviously be hotter around the exhaust and at the top of the cylinder.
WINTERMODEL150
Hi,anywhere from 180-230 degrees c at the spark plug at constant speeds depending on engine set up, a piston will seize at anything over 250 degrees c ,hope this helps.
Dean
diesel
Thats great ,thanks
    Users browsing this forum: Google [Bot] and 17 guests
