Fuel Flow Problem
Posted: Wed Jan 18, 2012 3:28 pm
by Bilko
I've got a problem with the fuel flow rate on my GP
From the tap it's fine, over 400ml a minute.
But when I take bottom of the carb off, the flow rate is 200ml a minute.
Re: Fuel Flow Problem
Posted: Wed Jan 18, 2012 3:31 pm
by Bilko
Just to add:
This is with the in-line filter taken off and a very clean carb.
Posted: Wed Jan 18, 2012 3:36 pm
by mark
what size float jet?
Posted: Wed Jan 18, 2012 3:39 pm
by coaster
Have you checked the float valve is clear and the filter in the carb if it has one. If it's a PHBH the siize of the float valve is important, post up what you have and someone more knowledgable will tell you if its big enough
Posted: Wed Jan 18, 2012 4:06 pm
by Bilko
Thanks Colin. The valve was a 200. With advice from Jarv, I've tried a 300 and it improved the flow to 300ml a minute. I don't have a bigger size to use til the end of next week.
Posted: Wed Jan 18, 2012 9:39 pm
by soosh
300 should be fine.I've been using that size for years now.
