Effective dome volume or not effective dome volume?
Supereibar
When calculating compression ratio, do you substract the effective dome volume or it isn't necessary?
Cheers,
J.
Supereibar
Ah! Eden! I was talking to Russ about this, since you mentioned once. What do you mean, do you just do it when measuring with the cylinder head on or you meant actually doing it a different way?
