Jetting TS1 225 - Old NK Race - 30mm PHBH
Bilko
Main scooter: LI150
Sorry for posting this in here, but sometimes the carb section can be neglected. :?
Can someone suggest jetting for a TS1 225 on an old NK Race with a 30mm Dellorto?
Thanks
Bilko's Oily Blog
DaveTomo
Main scooter: SX 200
off the old AF site,should get you somewhere near,down the bottom TS1 225 with expansion
mickdale
isnt X7 on 2nd clip with AV266 lean on a TS1?
Bilko
Main scooter: LI150
Thanks for the link
Bilko's Oily Blog
nelson pk
mickdale wrote:isnt X7 on 2nd clip with AV266 lean on a TS1?
I agree. I would start with an av268 and x2 and work down on the needle if its too rich. Personally i would think an x7 second clip down in an av266 will lean out at high speed cruising in the half throttle range.
col68
Main scooter: lambretta s2 li225 ts1
hi mate I had my ts1 225 30mm phbh jl3 set up by chalke at replay in june on his dyno 138 main 55 pilot 40 slide 300 float av266 needle x7 2nd clip open mouth . it just a little rich at fully throtle . any help col
Bilko
Main scooter: LI150
col68 wrote:hi mate I had my ts1 225 30mm phbh jl3 set up by chalke at replay in june on his dyno 138 main 55 pilot 40 slide 300 float av266 needle x7 2nd clip open mouth . it just a little rich at fully throtle . any help col
Thanks, what atomiser are you using?
Bilko's Oily Blog
DaveTomo
Bilko
Main scooter: LI150
:oops: Sorry. I read it twice and missed it. :oops:
Bilko's Oily Blog
