2 magneto housing gaskets
doggbhoy
hi all ,
mb don't have any 1mm thick magneto housing gaskets in stock so got two 0.5mm ones to use together(with a sealent).....
anyone think that this might be dodgy?
appreciate any thoughts on this thanks in advance
and have a merry and happy christmas
:fb: :D
I would think that'll be fine.
Supereibar
That should be fine, just make sure you use some instant gasket as well, that will make it better sealed. You could also use different thickness gasket paper if someone near you can lend you some. A gasket is very easy to make :D
