Crown Wheel
Posted: Sat Dec 03, 2011 9:37 pm
by Jeff T
I've 5 plate clutch and getting a bit of drag in 1st so was going to replace the crown wheel with one that's machined for the clutch plate, what's the advantage or disadvantage of fitting a lightened one and will it make any difference to current set up ony I fitted an Imola last winter and fairly happy the way it's running and don't want to screw it up.
Re: Crown Wheel
Posted: Sat Dec 03, 2011 10:14 pm
by RICSPEED
wont make any diff to cluch action
Re: Crown Wheel
Posted: Sat Dec 03, 2011 10:19 pm
by Jeff T
I thought if the crown wheel is machined for the lugs on the clutch it gives it more room for the clutch to release.
Re: Crown Wheel
Posted: Sat Dec 03, 2011 10:21 pm
by RICSPEED
Jeff T wrote:I thought if the crown wheel is machined for the lugs on the clutch it gives it more room for the clutch to release.
yes but you said lightend one
Re: Crown Wheel
Posted: Sat Dec 03, 2011 10:29 pm
by Jeff T
ok sorry the questions I was asking is I'm changing the crown wheel for one that's machined for the lugs on the clutch should I fit a normal one that's machined or a lightened one that's machined and what difference will the lightened one make on current set up if any.
Re: Crown Wheel
Posted: Sat Dec 03, 2011 10:49 pm
by RICSPEED
lighter is better ...but both should be better regarding the cluch action
as far as lighted goes its a good idea ...but point less i would say if the engine is otherwise standard
