Eibar SX200
RBG
I'v just got myself a 1974 Spanish SX200 frame will Italian SX forks fit?
I've looked through the posts and it only gives the fork length for the later large
damper type.
is the frame a chrome ring type at all ... not sure if spainish frames had them but if the forks are for non ring and your frame is also they should fit
RBG
The frame is totally bare, I'll take a measurement of the fork tube as soon as I can.
Supereibar
Italian chrome ring type forks will be too long... You will have a wide gap there to fill. Poss fitting a chrome ring will solve your problem.
Best,
J.
eibarlad
Around 74 the jet lost the chrome ring but the chrome ring headset/legshield's we're retained.
Just check the frame by the headset, tab at the back for steering lock non Chrome ring-no tab but thread for grub screw round the front of the tube means a ring was fitted.
Being a 74 it will have probably been badged as 'serveta'
eibarlad
[imImageg][/img]
This is a 72 eibar, I'll measure the forks when I get in the garage
RBG
Had a really busy day but managed a quick look and its non Chrome ring.
    Users browsing this forum: Semrush [Bot] and 11 guests
