Viton seals or not
TS1-200
Lots of talk on here recently regarding the pro`s and con`s of Viton oilseals, after holing a piston due to base gasket disintegrating,I`m in the process of re-building, I`ve got Viton seals in at the moment, but do I replace with viton or normal type Rolfe seals. I put the viton ones in at the same time as I put in the crap base gasket in .
Keep on keepin on
are they ok or crap?that should tell you tbh
Muppet
think viton seals were a fix for something that was never really broken,
muppet,
C’est la vie
jonashford
Ive run them in my rb this season over 4000 miles no problems they will be in again for the next season, hopefully more miles this year
rog60
Main scooter: Indian GP200
Bought a set from MB 3 years ago after rolf seal failure................no probs
gadgetman
Viton seals were advertised a a cure for the problems of ethanol damage but unfortunately Viton is NOT resistant to ethanol as you will find if you check it out in the web
Special X
Should be resistant to ethanol as the viton tipped (red) delly float valves are for ethanol resistance.
Always insist on GF-S Viton seals :-?
Special X
Using no ethanol gave good results, using pure ethanol gave good results. Seems to be the mixture of the 2 thats not good.
    Users browsing this forum: Google [Bot], Semrush [Bot] and 2 guests
