Dodgy Dampers?
Bilko
Main scooter: LI150
Anybody ever have this happen to them?
Unused set of dampers
WTF is all that about?
Bilko's Oily Blog
Bilko
Main scooter: LI150
Yip.
Got another pair to try.
Bilko's Oily Blog
YOU NEED SOME 19MM REPAIR WASHERS THESE HAVE A 4.5 MM HOLE IN THEM SO NEED TO BE DRILLED OUT PUT ONE EACH SIDE OF THE BOTTOM EYE AND DO THE NUT UP NYLOK IS BEST THATS AFTER YOU HAVE PUSHED THE RUBBER BACK IN
Bilko
Main scooter: LI150
Cheers, I'll go se if I can find some.
Bilko's Oily Blog
Bilko
Main scooter: LI150
Thanks for the info troops. Now sorted with the washers. :D
Bilko's Oily Blog
