Standard SIL GP200 / JL3 pipe / Dellorto 30mm PHBH carb
Posted: Wed Mar 25, 2009 9:48 pm
by cranky
Can anyone help with the jetting / needle / float info please with reference to the above set-up ?
Barrel is the standard cast iron stage 4 type.
No other mods to the scoot (apart from Taffspeed clutch springs) and scoot has been run-in to the letter.
Cheers
Re: Standard SIL GP200 / JL3 pipe / Dellorto 30mm PHBH carb
Posted: Sun Dec 25, 2011 10:41 am
by mickdale
i had good results with
125 main (to be safe)
AV264 atomiser
X13 needle 2nd clip
53 pilot
Posted: Sun Dec 25, 2011 12:40 pm
by lamblast
or try av266 x7 needle second clip 50 pilot 122 main but try 125 main first to be safe 40 slide and it might be an idea to put a 300 needle valve in hope this helps
Posted: Mon Dec 26, 2011 10:05 pm
by Andy Pickering
Lam46 wrote: GP200, iron barrel stage 4 Sean Brady tuned,
30mm Dellorto
122 Main
AV264
PM25 Pipe
Augusto 7000:
Blue line pre fettle and dyno, Red line final run after fettle..
:D
PM Pipe !!
