Standard SIL GP200 / JL3 pipe / Dellorto 30mm PHBH carb
cranky
Can anyone help with the jetting / needle / float info please with reference to the above set-up ?
Barrel is the standard cast iron stage 4 type.
No other mods to the scoot (apart from Taffspeed clutch springs) and scoot has been run-in to the letter.
mickdale
i had good results with
125 main (to be safe)
AV264 atomiser
X13 needle 2nd clip
53 pilot
lamblast
or try av266 x7 needle second clip 50 pilot 122 main but try 125 main first to be safe 40 slide and it might be an idea to put a 300 needle valve in hope this helps
Lam46 wrote: GP200, iron barrel stage 4 Sean Brady tuned,
30mm Dellorto
122 Main
AV264
PM25 Pipe
Augusto 7000:
Blue line pre fettle and dyno, Red line final run after fettle..
:D
PM Pipe !!
