forged or standard ?
Posted: Thu Oct 20, 2011 8:36 am
Not being a Metallurgist or Chemist just a Technician :biggrin:
Could someone answer a question for me regarding forged pistons ~ standard pistons ?
During a span of 37yrs both thrashing and sensible riding ( 2-strokes ~ yam - lam - suzuki - kawasaki - yamahas up to 500cc)
Never once had a pin drop from a standard piston only very occasionally from a forged piston
Lads now including myself using Pump fuel (5% ETHANOL + Quality Oil ) Riding the same speed/distance and engine setups
Having pin problems with forged pistons not standard ones
Mr
recommends you change their forged piston rings and check the pins every 1500mls (
Is it the Ethanol or other additives/abrasives reacting with the metal structure of a forged piston rather than the silicon based standard pistons ~ Causing the pins to drop or a manufacturing fault ?
As the present additives were not used on the pistons I had drop pins years ago
Mr
