forged or standard ?
mnpes
Not being a Metallurgist or Chemist just a Technician :biggrin:
Could someone answer a question for me regarding forged pistons ~ standard pistons ?
During a span of 37yrs both thrashing and sensible riding ( 2-strokes ~ yam - lam - suzuki - kawasaki - yamahas up to 500cc) ;)
Never once had a pin drop from a standard piston only very occasionally from a forged piston :cry:
Lads now including myself using Pump fuel (5% ETHANOL + Quality Oil ) Riding the same speed/distance and engine setups
Having pin problems with forged pistons not standard ones
Mr :lol: recommends you change their forged piston rings and check the pins every 1500mls ( :cry: )
Is it the Ethanol or other additives/abrasives reacting with the metal structure of a forged piston rather than the silicon based standard pistons ~ Causing the pins to drop or a manufacturing fault ?
As the present additives were not used on the pistons I had drop pins years ago
soullad
Good call
let the debate begin :)
fred
I've always run piston ported motors. Only ever had ring peg probs twice,both were forged pistons. First was wiseco suzuki 205,peg fell out after about 5k miles :oops: my fault for lack of maintainence.
2nd was wearing of peg on mb piston,ring went over peg,and into exhaust port,this was 200 miles after re ringing a piston that'd done 1000 miles. this was a few years ago,mark put it down to super plus unleaded. never used it since. No probs since,but i do tend to re ring mb pistons every 1000 miles,or so.
Used to run honda 205 pistons for 10 rallies a year,plus work and back in the 90's,and re ring every year-18 months. Never had a problem with these pistons,except needing a rebore every couple of years. Shame they only did 3 sizes. Pretty sure honda used cast pistons.
Next year i'm going to try a goetze piston. But if this is not up to it will have to use a mb piston.
Until someone brings out a cast piston with 1mm wire rings,there's not much choice if using piston ported motors with 16mm gudgeon pins.
    Users browsing this forum: No registered users and 74 guests
