28phbh Dellorto
wally
Main scooter: Lambretta GP 200 & Li 150
Just about to fit a 28mm phbh Dellorto to my stage 4 tuned GP200, i have a 42mm Clubman exhaust fitted and i'm needing some advice with regards to what are the best settings etc for jet's and set up etc.
cheers ;)
Take a look through here Wally on lam set up http://scooterotica.org/forum/viewtopic.php?f=9&t=14
wally
Cheers mate, but i read all them before posting as non have a set up using a 42mm clubman and 28mm open bell mouth dellorto carb.
there should be loads of members with similar set ups around..dump the 28 and sling on a 30mm a few set up up for that.. :D or you could get it dynoed..?? you know its spot on then.. ;)
wally
Many thanks for the info, yeh thats what i'm hoping to do once i've got it up and running, anyone know of a Dyno centre near to Middlesbrough?
Scooterotica dyno centre (Housed in Sean Brady Scooters) in Ripon is not to far from the boro is it..good service..(but I would say that cause ive used it) :D
http://scooterotica.org/forum/viewtopic ... 12&t=12593
Last edited by Andy Pickering on Thu Sep 29, 2011 4:44 pm, edited 2 times in total.
Reason: added link
