jetting.
psychedelicropcircle
Running an imola 186 with ancillotti clubby,
28mm phbh,
55 pilot,
115 main,
av264
x2 needle 2nd clip from top,
40 slide
Holed two pistons on this set up tried various things retarding timing changing cowling up jetting, I now think the atomiser is to lean, changed today to a av266 and a 115 main (smallest I had). cylinder was getting flooded smoking heavy but most importantly done a tank of fuel in 50 miles....granted it would only run right at flet oot :ninja:
I plan to try a smaller main. Have seen folks using much the same set up but with a AS266 atomiser. It would be much appreciated if someone who has experience of a similar set up posted up there findings.
regards scott.
    Users browsing this forum: No registered users and 102 guests
