high tick-over from cold
db67
hi, got a slightly annoying problem with my scoot at the mo, from a cold start it has a tendency to tick-over quite high for a couple of minutes before settling down to a more sensible speed once it starts to warm up,engine is a ts1 225 running a 30mm dellorto,remote air filter & jl 3 exhaust. carb starter jet is 70 & mixture set at 1 1/2 turns out, i've checked for air leaks & that the throttle or choke cable i'snt to tight & can't really find anything else that seems to be causing this,any help or ideas greatly appreciated. thanks in advance. db67 :)
wack 63
Main scooter: '71 GP TS1
One of my mates TS1 does the same although he runs a 35 TMX ,once warmed up it ticks over fine.Weird
