lack of performance
roadrunnerian
i have a ts1 225 which had an amal mk2 carb on since i changed the carb to a tmx 35mm i have noticed a lack of top end power. i know its a lot smoother really low down you can pull away from 25mph in 4th no problems any ideas thanks
wack 63
Main scooter: '71 GP TS1
You need to post what jetting you are using but I have 300 main with Ramair,and a 56 needle in mine.
roadrunnerian
hi the jetting i have is a 350 mains and needle en 11-55 on the 2nd clip plus its open bell mouth. thanks :?
