Painting advice...again.
Posted: Wed Sep 14, 2011 7:19 pm
Thinking about adding some colour to the scooter over the off season. Im going to respary the whole scoot in the same colur as present but add some pepper white lines and flashes, also need to think about a colour for a pinstripe which will edge the flashes and lines. Prev I have only sprayed the one colour so no experience of adding another colour on top or pinstriping....
I have been pleased with the results of the prev spray but it wasnt perfect with some orange peel in places. This was my fault as i didnt rub down either the base coat or the laquer when applying or mop the finished thing with a compound. This time i have more time to spend so would like to try and get a better finish.
Really im looking for advice on a good step by step process to get the desired effect. I have in my head whats the right way to go but iv probably missed a stage out or got it wrong. Also there may be better ways/order to doing pinstrping and secondary colurs?
Using Base coat & laquer: Colour Aston Mart old english pewter, Mini pepper white & pin colour tbd
(using side pannels in this example)
1/ Spray pewter base coat (grab coat + 2 further coats)
2/ Rub down lightly with 1200 (panel wipe & tac)
3/ Mask off areas for white to be sparayed (panel wipe & tac)
4/ Spray white base coat (grab coat + 2 further coats)
5/ Remove masking tape (how long should you wait to do this, until it has gone off or before its fully dried?)
6/ Rub down lightly with 1200 making sure not to go through edge (panel wipe & tac)
7/ Mask off all panel apart from pinstriping and spray 3rd colour (grab coat plus 2 further coats)
8/ Remove tape (same question as 5?)
9/ Rub down lightly with 1200 making sure not to go through edge (panel wipe & tac)
10/ Spray 3 coats laquer rubbing down with 1200 between each
11/ Mop pannel with approiate compound
12/ Polish with correct compound
Any help greatly appeciated
sef
sef
