GP Panel Work
Posted: Mon Sep 05, 2011 9:18 pm
by Jeff T
My side panels catch the rear floorboards towards the front of the side panel and rub the paint off, although you can't see it it's bloody anoying is there way of adjusting this, I can't see how as the cross member is welded in position I've even taken the rubber washers off from under the floorboards.
Thanks
Re: GP Panel Work
Posted: Mon Sep 05, 2011 10:01 pm
by WINTERMODEL150
You will have to push the legshields forward but this is a lot of work as you need to undo all the fixings holding the legshields to the cross member and to the main front of the frame.
Dean
Re: GP Panel Work
by WINTERMODEL150
Dean
