GP Panel Work
Jeff T
Main scooter: GP150 & LI150 S2
My side panels catch the rear floorboards towards the front of the side panel and rub the paint off, although you can't see it it's bloody anoying is there way of adjusting this, I can't see how as the cross member is welded in position I've even taken the rubber washers off from under the floorboards.
Thanks
WINTERMODEL150
You will have to push the legshields forward but this is a lot of work as you need to undo all the fixings holding the legshields to the cross member and to the main front of the frame.
Dean
WINTERMODEL150
Dean
