Going on the chart in this link it is somewhere between numbers 6 and 11. So that's not too bad.cezeta wrote:im trying to avoid clouding your mud....![]()
pinking is associated with leanness and heat while under load/acceleration. it tends to be a bit more responsive and lively when it does it as the heat gives better power. having said that if its super lean then it will not pull.
you can use your choke, when it feels as you describe flick the choke on and if it feels better then its likely to be lean but if its worse then its rich.
what color is the plug?
