12V DC Conversion with Battery - Wiring help needed, please!
Posted: Fri Aug 26, 2011 11:08 am
I understand that by adding a battery to the DC conversion it means that the lights can remain active even if the engine stalls/cuts out (i.e. they continue to be powered by the battery), which is helpful if the engine dies on an unlit road at night and you still want to be visible.
However, to stop someone pratting around with the brake light, horn, and indicators when the Lammy is left parked up, can someone please advise the best way to connect up the loom, battery, and ignition switch so that the brake light, horn, and indicators aren't permanently live/active, even when the key is out of the ignition?
I have looked at various threads on here and all the wiring diagrams in Sticky's manual, but keep going round in circles (mainly due to the many different wiring approaches Innocenti, Serveta, and SIL appear to have adopted over the years!). I think that the only way I can isolate the brake light, horn, and indicators would be to feed these via the auxillary power wire from the ignition switch (usually a grey or purple wire on a standard Lammy ignition switch). Is this correct?
I intend to make my own custom loom using Thinwall cable from VWP, so that I can run the main power feed (from the battery/Wassel unit) direct to the headlight junction block, rather than via the brake switch and horn, and then feed everything from there.
For a bit of context/background, I have an Eibar S2 Winter to which I intend to add a key ignition switch (in place of the cut-out button) to control lights on/off and then use a late Indian GP traprazional light and indicator switch to control the high/low beam and the indicators, which I will be adding via a rear number plate embellisher and 2-pin flasher unit.
Apologies for the long thread, but hopefully all the info will help someone to help me!
A
A
