can a 125 casing be converted to a 200 on a vespa?
cezeta
any one offering this services?
Think disco Dave can get this done. He did a few lml reedvalve 150 to 200 conversions. Lulls of years ago
OzOAP
Main scooter: Vespa PTS1E
Can be done, I did a couple for Dave. Wouldn't dother though. Plenty of decent kits for 125 casings now days. Its a bit of work modding for 200 barrel and even more work to fit 200 crank.
A 200 crank can be modded to fit into 125 casings but ur very limited on inlet width.
cezeta
is there a kit that will give equal performance to a polini 208 (i dont know anything about the smaller kits or engines) or am i better off buyng 200 casings and fitting the internals into it?
stirling.....are you oz?
guygrrr
Main scooter: 1980 Vespa P187
Stirling Hopkirk wrote:Can be done, I did a couple for Dave. Wouldn't dother though. Plenty of decent kits for 125 casings now days. Its a bit of work modding for 200 barrel and even more work to fit 200 crank.
hey Stirling, i thought it might be novel, down the road here a bit, to put one of these together. i think i understand what needs to happen, welding the ports up, machining the mouth, gasket face, a recess for the crank and drilling for the studs. is there anything else you found? would you do something differently? fit a ts1? ;)
thanks!
more can do, less doodoo.
gadgetman
Yes a Quattrini MIXL 172 will give better performance than the Polini and still return 45 mpg ( which is important considering the Vespas small tank)
cezeta
eeeek, thats about 50 miles to a tank
tony
Main scooter: 90ss
And the 125 case has proper stud config.. unlike the 200... loads of scope... need a long stroke crank to get the cc's up.. I dont know if there is one.
cezeta
can you expand on the stud configeration bit tony, i dont know anything about vespa small block engines.....infact the only thing i know about the big block is that it biggerr than the small block :oops:
OzOAP
cezeta wrote:is there a kit that will give equal performance to a polini 208 (i dont know anything about the smaller kits or engines) or am i better off buyng 200 casings and fitting the internals into it?
Dam, my cover has been blown :ninja:
My scootercrosser Malossi '166' has a fair bit of power, although it does have a 60mm P2 crank in it (175cc). The engine, with different gearing, use to be in my rally going machine. Would make much larger bikes look silly. :P
The new 172 that Mr Gadget mentioned is a powerful kit, not sure on reliability as I dont know anyone that is running one.
    Users browsing this forum: No registered users and 30 guests
