Series 2 Panel Alignment
Posted: Thu Aug 18, 2011 7:47 pm
by soulsurfer
Just doing the dry build on my Series 2 Winter and the back edge of the side panel is hanging below the tail of the frame, frame rubber and buffers are fitted. Now, I know these aren't the original panels, but is there a way of lining them up better to get an even gap along the rear footboard or lining up at the back?
Re: Series 2 Panel Alignment
Posted: Thu Aug 18, 2011 7:59 pm
by Supereibar
Welcome to my world... I've been dealing with this issue since I ever started with series 2 obsession. The truth is you will need to do as you yourself suggested and try first with rubber. Then if that isnt enough, fettle a bit with the edge of the sidepannel & the frame itself.
J.
Posted: Thu Aug 18, 2011 8:12 pm
by RICSPEED
how well do the pannels line up on the other frame mike?
Posted: Fri Aug 19, 2011 8:56 pm
by soulsurfer
A quick change of panel rubbers seems to have sorted it...
Casa rubbers are crap, as are the SR ones, but for the second time now, the ones that come up trumps are ScootRS
Posted: Fri Aug 19, 2011 9:00 pm
by RICSPEED
well done scootrs then
Posted: Fri Aug 19, 2011 9:09 pm
by soulsurfer
RICSPEED wrote:well done scootrs then
I'm sure it'll be quoted somewhere
Posted: Fri Aug 19, 2011 9:30 pm
by RICSPEED
soulsurfer wrote:RICSPEED wrote:well done scootrs then
well ...may be ...if he can veiw this page
Posted: Fri Aug 19, 2011 10:24 pm
by soulsurfer
Aahh, block 'im, I don't want to be part of his circus
Posted: Fri Aug 19, 2011 11:55 pm
by RICSPEED
