Series 2 Panel Alignment
Just doing the dry build on my Series 2 Winter and the back edge of the side panel is hanging below the tail of the frame, frame rubber and buffers are fitted. Now, I know these aren't the original panels, but is there a way of lining them up better to get an even gap along the rear footboard or lining up at the back?
Supereibar
Welcome to my world... I've been dealing with this issue since I ever started with series 2 obsession. The truth is you will need to do as you yourself suggested and try first with rubber. Then if that isnt enough, fettle a bit with the edge of the sidepannel & the frame itself.
J.
how well do the pannels line up on the other frame mike?
A quick change of panel rubbers seems to have sorted it...
Casa rubbers are crap, as are the SR ones, but for the second time now, the ones that come up trumps are ScootRS :shock:
well done scootrs then :D
RICSPEED wrote:well done scootrs then :D
I'm sure it'll be quoted somewhere :roll:
well ...may be ...if he can veiw this page :lol:
Aahh, block 'im, I don't want to be part of his circus :alien:
