Does Anyone know where i can get a digital CHT gauge?
wax
Hello there.
I have a Westach (?) CHT at the mo', but my highly strung TS1 240 makes the needle shake so much that its useless. The reading could be anything between 100-300 degrees, as far as i can tell. Neither use nor bloody ornament.
I figure that a digital one would avoid the shakes, but i am struggling to find one that will it in 55mm hole that i have drilled in my toolbox.
There are plenty of water temp gauges, that only read to about 150 degrees C, but not any round digital CHT ones.
Also, the sender that fits under the spark-plug is a bit fiddly and i have snapped one already. Is there another option that can be screwed to a fin on the head or summat?
