The gay monk does exist...
soosh
He tuned this motor..
Picked this up in a box of bits in 94 for £150 and the engine was already tuned by a kin top tuner in Oxford known as Big Dad or by others as The gay monk.Its an ET3 topend ported to fuk and crank cut.26mm carb,copy of a Taff snail and total loss ignition.It turned out to be a genuine 90 racer and stamped V9SS2.Oh well.Never really setup properly but would still do the 1/4 in just over 17 sec and 72mph.
The white rally in the garage is another gay monk motor,it was the old scooter scene project malossi and did a 15.6 at 80mph,that was built in 1987.
Where is the Rally now??
soosh
Muttley McLadd wrote:Where is the Rally now??
The rally frame is this..... :cry:
The motor is a bit like Triggers broom,yeh its still going but has had new casings and a new topend ;)
It was a work of art though,just perfect.The pipe was hand built.It revved well but just still pulled like mad in each gear,the reed was off a TZ750 i think and it covered both sides of the casings.This guy also did a mates T5 still using the 125 topend and it revved to 10,100rpm in 4th :o Aint got a T5 gearing calculator to hand but im sure others can work out the mph and still had the standard T5 carb.
soosh wrote:This guy also did a mates T5 still using the 125 topend and it revved to 10,100rpm in 4th :o Aint got a T5 gearing calculator to hand but im sure others can work out the mph and still had the standard T5 carb.
That's about 60, isn't it? ;)
soosh
Im sure its 62.
